any Century LP carb experts?
Rich Iowa
I posted this on the Oliver page but since there are so many Minnis running on LP, I thought I'd ask here as well.
Have a weekend with no plans and it will be some what warm so I will finally be able to mess with my 770 that was dying on me back in August. Once I look through the electrical (best I can) I'll turn to the LP fuel system.
I believe the carb is not original since it is a Century and I don't remember reading those came on the Oliver LP tractors from the factory, Plus there is the Century model H regulator/convertor that was added at some point. Curious if anyone knows about the Century carbs. The thin metal tag on the carb says;
"Century
3C-704UD
2006"
The body of the carb has part number 1A-35C
I've seen online I can get rebuild kits for the regulator/convertor but haven't seen anything for Century carbs. I've read about IMPCO and seems they might be easier to get parts for down the road.
Rich, Try Rob Ohda @ 815/379/2377. Rob works on a lot of the l.p.'s on the older Molines ,etc.,etc. Some parts are available for the Century systems. Make sure you tell him Dean refered you . Good luck
Thank you very much for the help. I'll write down his number and save it for when I turn my attention to the LP system.
I own several propane molines. Tell me more about what it was doing when it started dying.... warmed up? under load? etc etc. I too am in Iowa.
