Yesterday's Tractor Co.
Shop Now View Cart
Minneapolis Moline Tractors Discussion Forum
Show Parts for Model:
Re: mf95 super ......fuel system
12-28-2013 19:47:04
If you have stock valve springs, they will start to float around 2000 RPM. You can govern the Bosch pump to whatever you want simply by changing or shimming the spring, takes 30 seconds, I"ve done it between classes. I"ve had mine up as high as 3000. Mr. Moresmoke is right about the timing, you will need to advance your injection timing some if you"re going to run more RPM. Also, there is a way to turn the fuel up on that pump that takes about 3 minutes, if you haven"t done it already.
