Yesterday's Tractor Co. Fast, Friendly Parts Service
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Minneapolis Moline Tractors Discussion Forum
Show Parts for Model:
UTS brake adjustment
Handclutch
12-28-2013 16:31:58
203.193.209.213
I am replacing the oil seals on the brake shafts and find the brake adjustment is way out. A number of years ago I read a very detailed description of how to adjust UTS brakes. Thought I had kept it but can't locate it and I don't have an operators manual for this tractor. Can anybody provide advice or point me in the right direction?
[Reply]   [No Email]
Handclutch
01-07-2014 16:02:30
203.193.209.213
 Re: UTS brake adjustment in reply to Handclutch, 12-28-2013 16:31:58
Thanks for the replies, and thanks, Jim, for the offer to mail a copy of the manual but I am in Australia, so not terribly practical. I did find a printed version of the previous post that I had kept and then managed to find the link: http://search.yesterdaystractors.com/cgi-bin/viewit.cgi?bd=mm&th=35658
I have only worked on the left brake so far and found the top portion of the front lining had broken away and bent the shoe. I pressed that back to a curve and then followed the adjustment instructions, and that brake now feathers nicely. I will still replace the linings. Local brake service can bond "roll on" linings but wanted to know the thickness. As far as I can work out, they look like 1/4" but maybe 5/16". Does anybody know for sure?
Jack
[Reply]  [No Email]
jnf
12-29-2013 12:43:26
38.99.121.141
I have a manual for a UTU with the brake information. Call me with your address and I can mail you copies of those pages. 660-542-2117. A UTU has shoe brakes and may be like your UTS. Jim
[Reply]  [No Email]
mmfan55
12-28-2013 18:55:18
98.93.244.23
I assume you are working on the model that has a brake drum mounted on the side of the rearend / trans housing. There is a slot or hole in the brake drum. Move the tractor or tire (if jacked up) to about 11 o'clock. At that point you should be able to see the adjustment gear cog. Use a brake spoon (or flathead screwdriver) to rotate the adjustment gear. I don't remember which way to turn it; (up or down) but: turn it a bit check your pedal travel; and you will know if you are tightening or loosening it. (adjusts the same way as old drum brakes on an auto)
[Reply]  [No Email]
[Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
TRACTOR   PARTS TRACTOR   MANUALS
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2014 Yesterday's Tractor Co.
