What tractor had this
Mjfarms65
Found this generator on Cl. I was wondering what MM tractor may have used this engine? If the generator unit is no good does the engine have a value?
looks like a 5 gear which has a water pump which the tractor did not. The 5 gear will not fit into the frame without cutting the frame.
It's worth saving for it's age & oddity, I've only seen a few of these, all on CL, this is the only one that has, or shows the MMPIC engine tag. How much are they asking?
275 started couple weeks ago at 400. Was left in barn for new owners. What I find odd as a electrician is the 3 phase 125volt. Very odd.
