roosa master pump
I"m looking for a 6 cylinder roosa-master pump and accessory drive from a g 1000. My plan in to put them on a GB diesel. I have had the Bosch pump rebuilt but for the life of me I cannot get it to run right...timing?? Please help
Setting the timing on these is quite a process. The timing for my UBD is 27 degrees BTDC and the 670 diesel is 29 BTDC. I'll look up the GBD tomorrow. If you need help setting your timing, let me know and I can walk you through it if you'd like. My email is open, send me your number and I'll give you a call. If you had the pump gone through by a shop, there's no reason it shouldn't run.
