I had to drain the differential on my Jetstar 3 super. The book says 40 quarts of fluid, but I don't find a oil level plug for the differential. There is a plug for the tranny just above the serial plate. Is this an oil level plug and does it serve the tranny and differential
There should be a small plug on the side of the tranny near the brake pedals. The large plug on top of the tranny is for filling the tranny and rearend.
There is a separate plug for the oil level in the torque-amplifier (if your tractor is so equipped).
NO, AGCO Prairie Gold isn't right for anything. you want the MM "Yellow" John Deere Industrial Yellow is just about a perfect match. School Bus or Highway Yellow is as well.
For our Jetstar Two '63 we used Sherwin Williams energy yellow code #8511, colour came out perfect.Dana brown S-W code #31322. In USA understand Martin Senour is US side, same company. jack
