Bosch Inline
molinegb
Anyone every worked on the Bosch inline pump. I have fuel to top but no output.The rack moves but is tight. Once tops and springs put on it tightens up. Rack is in center position.(furthest to right)
I run a small pump shop and have had my hands in my share of bosch pumps. I NEVER charge a guy for calling to get advice or help with a pump problem. Give me a call and I will try to help you out. 231/757/0064
I have fuel at injectors. But 4 screws on side which I shouldn't have removed seem to be the issue. First two are back in position and rack movement ok. Last two different story. They won't go in and leave plungers free. Can they be 90 degrees out? I can see holes but they just don't line up true.
