Yesterday's Tractor Co.
Shop Now View Cart
Minneapolis Moline Tractors Discussion Forum
Show Parts for Model:
Re: Help - 39 RTS Transmission Issues
10-17-2013 13:05:09
Thanks for the pictures - I'm thinking my problem must be wear at the top fork on rear of center rail under shift lever - somehow the center shaft has jammed into the guide so that it can not move either forward or aft unless I get lucky - once in a blue moon. Most likely I need the center rod and / or the guide. Guess I'll have to take top off to figure it out.
clyde in colo
10-23-2013 12:12:28
 Re: Help - 39 RTS Transmission Issues in reply to MMEd, 10-17-2013 13:05:09
This guy has 3 listings.......depending opn which rail you want.
11-03-2013 04:50:46
 Re: Help - 39 RTS Transmission Issues in reply to clyde in colo, 10-23-2013 12:12:28
Thanks - I bought all 3 rails. But they are significantly worn. When I got trans apart, only need 2nd / Reverse rail - it was rusted solid to ball and rear guide. Other 2 are in much better shape wear wise than the ones I bought. Guess I"ll put it back together with used rail and see how it shifts - and keep looking for a better 2nd/R rail. Based on wear possible issue would seem to be popping out of gear.
