looking for head for 51 uts
molinebob
Wondering if anyone has a head or set of heads for 1951 mm uts. Im in northern minnesota so shipping might cost me alot but need a head. Even a lead on th where I can find one would be awesome...thanks in advance...Bob
We need to know the casting number that is in between the spark plugs. I have most numbers on hand. Give me a call 308-940-0255. Thanks Jeff
I will get them tomorrow, tractor sits 100 miles away, take a trip out there tomorrow after work...thanks...
You most likely have GE30E heads which were 5.5:1 Compression. They were replaced by 10A4209 also 5.5:1. My UTS has one of each and runs fine.
The more desirable heads would be the GE30M or GE30Z or 10A4210 which were 6.95:1 Compression Ratio. If you are changing both heads, you might want to consider upgrading - just make sure you have the correct Head Bolts and Pushrods. The Head height for the GE30E was 5 inch but the GE30M and GE30Z were 4 17/32 inches.
