TractorLinks.com
Minneapolis Moline Tractors Discussion Forum
Show Parts for Model:
Re: ztu tune up
ACEd
10-17-2013 08:17:41
Point gap of 0.020 s/b correct for Fairbanks Morse Magneto. What are numbers on Magneto - I think a 44 ZTU original s/b FMK4B4.
That decodes as follows: FM = Fairbanks-Morse; K = basic design (with disc rotor under a one-piece top as opposed to later J or X models that had removable rotors under separate caps); 4 = 4 cyl; B = flange mount or A = base mount; 4 = MM Application with 25 degree preset - other numbers indicate other tractor brands potentially with different Presets. (3 = AC, 7 = Continental, 11 = IH, 73 = Ford 2N?) As I understand it the Preset is essentially a built in fixed advance.
Other magnetos can be and often are swapped in - As I understand it, the later FMJ4B4 or FMX4B4 should be direct interchange for MM with same 25 degree preset. Other mags such as the FMX4B3 built for Allis Chalmers will work but Preset is 30 degrees instead of 25 degrees. The FMX4B3 works fine - I just put one in a ZTS in place of the original FMK4B4. I believe there were other applications which had Presets as low as 15 degrees. Not sure how, but I understand the presets can be changed if you know what you are doing, but not sure I would mess with it.
Why do you say you have timing problems - does it not run good or are you checking with a timing light? If it runs good, I'd leave it alone.
kermkep
10-18-2013 05:01:22
 Re: ztu tune up in reply to ACEd, 10-17-2013 08:17:41
It just didn't run good. I have removed it from the tractor and have it ready to send in to get repaired.The place I'm sending it to thinks the coil is bad. Thanks for your response.
MMEd
10-18-2013 05:45:13
 Re: ztu tune up in reply to kermkep, 10-18-2013 05:01:22
I would have thought Magneto Coil would clearly be either Good or Bad - if it runs at all, I would check Spark Plugs, Plug Wires, Carburetor, and especially Fuel Tank / Sediment Bowl / Fuel Lines - also check that Gas Cap is Vented. Possible exception to magneto being bad would be that it could go bad after it warms up. Best of luck. Ed
