Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Minneapolis Moline Tractors Discussion Forum
Show Parts for Model:
Re: MM 5 start steering problem
Alan K
10-12-2013 21:23:08
Did your power steering just suddenly stop working? Narrow front or wide front? (stuck spindles) I believe there is a valve in the pump just above the pto shaft you could check.
chrisaukcam
10-14-2013 08:29:24
 Re: MM 5 start steering problem in reply to Alan K, 10-12-2013 21:23:08
Wide front end. As best I can recollect it went out gradually. It isn"t used very often.
I can lift the front end off the ground with the bucket and it steers freely. So nothing is in a bind.
Cliff Nelson
10-14-2013 16:48:46
 Re: MM 5 start steering problem in reply to chrisaukcam, 10-14-2013 08:29:24
Have him check the flow divider valve on the back of the hydraulic pump. It splits the flow from the pump with part going to steering and the rest for 3 point and remotes. The fact that operating a remote will give you higher steering pressure tells me that the flow divider is not working properly.
