Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Minneapolis Moline Tractors Discussion Forum
Show Parts for Model:
Any good sources for g1355 parts/ battery cover/ decals
G1355
10-06-2013 15:10:03
Wondering if anyone out there knows a website or someone who makes a battery cover for a g1355, would also like to find a complete decal set, all warning decals, one for around dash, around gauges by hydraulic, pto and 3pt levers. And sure I will think of more it needs. Also on the ones with white sides with MM on front did side panels have a "nameplate" decals went on or the decals just on side panel thanks.
Klw445
10-06-2013 20:51:45
 Re: Any good sources for g1355 parts/ battery cover/ decals in reply to G1355, 10-06-2013 15:10:03
If you are curious about the holes in the side panels, I believe they were used on "white" models or possibly cockshut. I had the decals for the hyd, pto and the ac/heat plate made at a local sign shop. I can ask if they still have the template if you like. Not exactly cheap, but it dresses it up nicely. I would also be interested in the battery cover.
G1355
10-07-2013 05:12:08
 Re: Any good sources for g1355 parts/ battery cover/ decals in reply to Klw445, 10-06-2013 20:51:45
There are holes on my side panels, I actually found decals, dash and all for 50.00 here's the link, suppose to be for a 2255 but there the same thing. Just curious does yours say white or MM on the front.
Klw445
10-07-2013 05:30:24
 Re: Any good sources for g1355 parts/ battery cover/ decals in reply to G1355, 10-07-2013 05:12:08
I'm not sure what it was supposed to be...mine was missing when I bought it. So I made MM out of a piece of aluminum I had laying around because I think it looks better (not to mention, easier to fabricate).
Glad you were able to find the decals!
G1355
10-07-2013 11:05:31
 Re: Any good sources for g1355 parts/ battery cover/ decals in reply to Klw445, 10-07-2013 05:30:24
Can you post a picture of the MM, I made mine a MM don't like the white
Klw445
10-08-2013 10:14:25
 Re: Any good sources for g1355 parts/ battery cover/ decals in reply to G1355, 10-07-2013 11:05:31
I believe Alan gave some dimensions. I had already made mine, so it isn't exactly correct but it works for me.
g1355
10-08-2013 15:30:54
 Re: Any good sources for g1355 parts/ battery cover/ decals in reply to Klw445, 10-08-2013 10:14:25
Heres mine i made. Yours looks better gonna try and redo it.
G1355
10-06-2013 15:10:38
Or if someone has pictures and dimensions of battery box cover I will just make one.
cleddy
10-18-2013 10:18:04
 Re: Any good sources for g1355 parts/ battery cover/ decals in reply to G1355, 10-06-2013 15:10:38
I don't know if this is what you need but this came off a U302 or M602 gas burner which takes 1 long battery. I would of thought lots of others would have had good battery covers to share with you but I found this one in the iron pile after a dozer pushed thing around some and was lucky to find it even though it is in poor condition. Hope it helps at this late date.cleddy
