Yesterday's Tractor Co.
Shop Now View Cart
Minneapolis Moline Tractors Discussion Forum
Show Parts for Model:
Re: G1000 LP vices diesel OK MM boys witch one????????
10-04-2013 11:01:12
Don't take this as bashing MM's, because I have been a MM guy for 30+ years. The G1000 would be the last MM tractor that I would want to use for work. Almost every G1000 that I have known of has had rear end(ring and pinion) failures at some point, and the thing is new ring and pinion sets are nearly impossible to come by these days.
Even the MM engineers at the time they were building them knew the design was not ready for production, but the company pushed them out the door anyway. MM did replace the bad ring and pinions early on. Some people I think are under the impression that the ones that were replaced are OK and will last forever, but many of the replacements later fail as well.
Alan K
10-09-2013 21:19:22
 Re: G1000 LP vices diesel OK MM boys witch one???????? in reply to Heath72, 10-04-2013 11:01:12
I had always heard about the ring and pinions in those. What actually happened with them when they failed? I had talked to a guy at a farm sale a few years ago. He said he had a G1000 and was out plowing and he quit moving forward. When he took the tractor apart he found all of the bolts that held the ring on were sheared off. Must be all that power up front.
10-11-2013 10:27:47
 Re: G1000 LP vices diesel OK MM boys witch one???????? in reply to Alan K, 10-09-2013 21:19:22
I was a Moline Mechanic back in the day. I have put at least a dozen ring and pinion's in G1000's. We thought at the time it was the spider gear shafts and the spider gears them selves. They at first were the same as U's and 705's etc. They went through 3 or 4 changes. Plowing in the furrow was the hardest on them. People who ran duals and chiseled seemed to have less problems. Vic
