Yesterday's Tractor Co.
Shop Now View Cart
Minneapolis Moline Tractors Discussion Forum
Show Parts for Model:
Re: 445 Industrial Hyd Pump-DEAD uh oh
09-24-2013 10:13:54
Yes, that bouncing around could have jarred something loose. I think that is what happened with the forklift. Worked just fine when I bought it, I had it hauled 100 miles to home, then it did not work. I figure the incline loading and road bumps caused the coupling to work its way to one end, like I said it is too short to start with. If you take the pump off the shaft should turn with the engine. The other end has splines on the flywheel. I suppose they could go bad, but that should make some grinding noise.
09-25-2013 16:53:01
 Re: 445 Industrial Hyd Pump-DEAD uh oh in reply to brian(MN), 09-24-2013 10:13:54
Well I found the problem, the coupling sleeve that goes from the PTO shaft to the pump is broken, I have attached pics. Any idea where to get one? Is this a standard part?
09-25-2013 18:10:00
 Re: 445 Industrial Hyd Pump-DEAD uh oh in reply to cmcgalla, 09-25-2013 16:53:01
I wonder if that is a standard sleeve for all hydraulic pumps on 445s? I might have one on my workbench, I'll have to look tomorrow.
09-25-2013 17:08:32
Wendell Everett will have the part you need.
740-922-3335. He will eventually answer.
