TractorLinks.com
Minneapolis Moline Tractors Discussion Forum
Show Parts for Model:
Re: 445 Industrial Hyd Pump-DEAD uh oh
brian(MN)
09-24-2013 06:05:17
I have a "56 445 backhoe too, that works, BUT, I have a Big Mo 500 forklift that the hydraulics just up and quit on me, just like yours. I pulled the pump off the back and figured out the little coupling between the pump and the shaft had worked itself off one of the shafts. I used some washers to shim it up so the coupling stayed on both shafts. Easy to fix but it took 2 weeks of spare time to figure it out. That coupling has a snap ring in the center to keep the coupling centered on the 2 shafts but it is an inch too short. They have splines like a PTO shaft. I hope this helps.
Jordan V
09-29-2013 19:03:05
 Re: 445 Industrial Hyd Pump-DEAD uh oh in reply to brian(MN), 09-24-2013 06:05:17
I just bought this beauty... a 335W backhoe... and am trying to figure it out... too impatient to wait for the manual... but one thing is stumping me... is there an e-brake on these things? if so, where. If not, is the only way to keep it from rolling away in neutral to put the outriggers down?
cmcgalla
09-24-2013 06:35:41
Also check this out: http://www.agcopartsbooks.com/PartsBooksN/Viewer/book.aspx?book=agco/r1157c00
This post was edited by cmcgalla at 06:39:43 09/24/13 2 times.
cmcgalla
09-24-2013 06:31:56
HI thanks for the help! I should have mentioned that the day before I was a bit stuck, came flying backwards over a mound of gravel and SLAMMED down hard enough to break one of the safety chains holding the hoe up. I wonder if in that jolt something worked loose?
If I pull the pump I assume I will see the shaft turning, if it is turning. . . right? And if that shaft is turning then obviously it has become disconnected from the pump.
brian(MN)
09-24-2013 10:13:54
 Re: 445 Industrial Hyd Pump-DEAD uh oh in reply to cmcgalla, 09-24-2013 06:31:56
Yes, that bouncing around could have jarred something loose. I think that is what happened with the forklift. Worked just fine when I bought it, I had it hauled 100 miles to home, then it did not work. I figure the incline loading and road bumps caused the coupling to work its way to one end, like I said it is too short to start with. If you take the pump off the shaft should turn with the engine. The other end has splines on the flywheel. I suppose they could go bad, but that should make some grinding noise.
cmcgalla
09-25-2013 16:53:01
 Re: 445 Industrial Hyd Pump-DEAD uh oh in reply to brian(MN), 09-24-2013 10:13:54
Well I found the problem, the coupling sleeve that goes from the PTO shaft to the pump is broken, I have attached pics. Any idea where to get one? Is this a standard part?
Thanks
Zeek
brian(MN)
09-25-2013 18:10:00
 Re: 445 Industrial Hyd Pump-DEAD uh oh in reply to cmcgalla, 09-25-2013 16:53:01
I wonder if that is a standard sleeve for all hydraulic pumps on 445s? I might have one on my workbench, I'll have to look tomorrow.
JK2
09-25-2013 17:08:32
Wendell Everett will have the part you need.
740-922-3335. He will eventually answer.
