GB wheel weights
jnf
We have a GB with 105# weights, 3 per side. The initial weight is held in place with two 3/4 grade 5 lug bolts. Subsequent weights are held onto one another with 3/4 bolts, two per weight. We have weights available to add two more per side. Will 5 be to much weight for the initial two lug bolts to carry. Anyone have experience with this?
I have put 10 wheel weights (10A373) on each side of my M5. I used (2) 3/4" grade 8 threaded rod on each side. I also used (2) 5/8" threaded rod on each side for a little more support. Hope that helps.
