Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Minneapolis Moline Tractors Discussion Forum
Show Parts for Model:
Re: MM emblem on 55 series grille
G1355
09-07-2013 19:06:11
What would you get to make a 10.5 by 4.75, so it's just a little bigger than Alan's measurements so it should be a little bigger than original, doesn't have to be anything to thick as long as it has a MM milled out. Or if you want my email I can give it to you. Thanks
cleddy
09-09-2013 10:36:41
 Re: MM emblem on 55 series grille in reply to G1355, 09-07-2013 19:06:11
As I e-mailed Allen at basic shop rate the one I did took 4 hours and that puts it in the $200.00 range. I'll need to get the dimensions of the corners of the "MM" itself to do a accurate job of centering it on the 10.5" x 4.5" aluminum plate. I can't tell from the picture if there is a space between the M's. If I get a chance to see one of them tractors around I'll make some notes about it. Someone mentioned there is a good muesuem over by Denison Iowa I would not mind seeing.cleddy
G1355
09-09-2013 11:48:58
 Re: MM emblem on 55 series grille in reply to cleddy, 09-09-2013 10:36:41
Hopefully I get the tractor by the end of the week, I'm gonna make sure there isn't one in the cab or anything as I only saw pictures. I will let you know.
Copyright © 1997-2015 Yesterday's Tractor Co.
