TractorLinks.com
Minneapolis Moline Tractors Discussion Forum
Show Parts for Model:
Re: MM emblem on 55 series grille
G1355
09-06-2013 11:19:29
No I have no sample, but I"ve seen them before its just thin, like tin, but aluminum would work, can you post a picture of the one you had made so I can see what it looks like. Thanks, and what was the cost
cleddy
09-07-2013 05:06:24
 Re: MM emblem on 55 series grille in reply to G1355, 09-06-2013 11:19:29
I can post these pictures of the original U302 & M602 Emblem which looks like cast aluminum and mine is milled out out of 1/4" thick aluminum plate. These are 5" x 7" and it took while to do(3.75Hr) so if the ones in the picture are quite a little larger it would take more time. As far as cost it would be excessive and I'm not really trying to make money doing this stuff so maybe we could work something out that is reasonable.
We have a later U302 Super Tractor that had a thin tinny emblem on so I wonder when they went with the changes on that. These emblems are solid cast aluminum and like Alan said maybe a lot of trctors had the same one. That why I would like to see a sample and how big the letters are. I'm sure anything new would be better than having none or a broken beat up one but my opinion is anything that been in use almost 50 years is going to have some character from it's use and abuse.
Cleddy
G1355
09-07-2013 19:06:11
 Re: MM emblem on 55 series grille in reply to cleddy, 09-07-2013 05:06:24
What would you get to make a 10.5 by 4.75, so it's just a little bigger than Alan's measurements so it should be a little bigger than original, doesn't have to be anything to thick as long as it has a MM milled out. Or if you want my email I can give it to you. Thanks
cleddy
09-09-2013 10:36:41
 Re: MM emblem on 55 series grille in reply to G1355, 09-07-2013 19:06:11
As I e-mailed Allen at basic shop rate the one I did took 4 hours and that puts it in the $200.00 range. I'll need to get the dimensions of the corners of the "MM" itself to do a accurate job of centering it on the 10.5" x 4.5" aluminum plate. I can't tell from the picture if there is a space between the M's. If I get a chance to see one of them tractors around I'll make some notes about it. Someone mentioned there is a good muesuem over by Denison Iowa I would not mind seeing.cleddy
G1355
09-09-2013 11:48:58
 Re: MM emblem on 55 series grille in reply to cleddy, 09-09-2013 10:36:41
Hopefully I get the tractor by the end of the week, I'm gonna make sure there isn't one in the cab or anything as I only saw pictures. I will let you know.
G1355
09-07-2013 13:59:18
I'll see what Alan comes up with for a measurement, then if you think you can make one like it, and have a price in mind we will talk if that works for you.
Alan K
09-07-2013 16:58:23
 Re: MM emblem on 55 series grille in reply to G1355, 09-07-2013 13:59:18
My G950 MM plate measures 10 1/4" left to right, and 4 1/2" top to bottom with approximately 1/8" in on each side and end is where the M starts. If you need more detailed measurements I can see what I can do.
Alan K
09-06-2013 17:06:30
I would like to see it as well cleddy..I have an M602 I might need one on.
G1355
09-06-2013 17:13:52
 Re: MM emblem on 55 series grille in reply to Alan K, 09-06-2013 17:06:30
Alan do you have any idea how big they are on a g1355, or an estimate, I have one coming that I know needs it. Getting exited for it to come.
Alan K
09-06-2013 21:10:15
 Re: MM emblem on 55 series grille in reply to G1355, 09-06-2013 17:13:52
From the info I found....the G955 and G1355 use the same Grille (cast iron housing), Screen, and the MM nameplate. With that being said knowing MM...Im guessing the grille would be the same that was used on the 950 1050 and 1350 flat grille models as I wouldnt think they would make a new casting, so I bet the MM would be the same on those as well. I can measure mine if you like. You will have to post pictures when you get it.
Alan K
09-06-2013 17:27:47
Im not sure, I can do some checking in the parts books to see if they are close to what they used on a 950 and I can measure mine.
G1355
09-07-2013 03:10:55
 Re: MM emblem on 55 series grille in reply to Alan K, 09-06-2013 17:27:47
Yeah if you'd measure yours that'd be great, I will post pictures as soon as it comes.
