What is it and what should i do?
kgreg
I just bought what i thought was an r standard but i got it home and realized its not. Its got an rtu serial number of 0015001666. It has a hand clutch, but has an industrial front end and steering box. What should i do, find an rti rear end, or a standard front axle or ??. Any input would be great. Engine and tractor are same color, so was this a facrory thing or is it homemade
Hopefully the picture will load. Also the loader is off of it now.
Just enjoy it the way it is. You could put a tricycle front end on it if you wanted it to match the serial number, but I would l leavethe rti front on if it steers ok. Farmers swapped front ends all the time on R's. I bet the rti front was put on to better handle the loader. I think it looks good.
