G900 diesel overheat wont turn over
bog
I was running the g900 down the road when all of sudden it got hot and started blowing water out of the radiator. I shut it off right away. But when i went to restart it after cooling down it wont turn over. It sounds like a piston is tight or something. The motor has not been run a ton after a rebuild. Maybe an hour. Someone started the rebuild 20 years ago and never finished it. I got the tractor and finished it. It ran fine, good oil pressure. It was not running hot, untill all of a sudden temp pegged and i shut it down right away. What might have gone wrong? What should i do now? Thanks.
