TractorLinks.com
Minneapolis Moline Tractors Discussion Forum
Show Parts for Model:
Re: G900 diesel overheat wont turn over
uncle boomer
08-29-2013 03:24:46
Sounds like coolant is in a cylinder. Don't keep trying to turn it over or you could bend a rod. Check oil and see if there is coolant in it. You may have to pull heads. These MM guys can help, hang on they will respond more for you.
SWMolines
08-29-2013 07:21:29
 Re: G900 diesel overheat wont turn over in reply to uncle boomer, 08-29-2013 03:24:46
I agree. It sounds like you may have blown a head gasket and started pushing gases into the radiator. That will also allow coolant into the cylinder.
If the engine will move by hand (even a little), it is not likely a stuck piston.
If it is water in a bore, you maybe able to determine which bore by openning the closed exhaust valves one at a time and seeing if the engine will turn completely over by hand. The water should push out into the exhaust manifold.
