TractorLinks.com
Minneapolis Moline Tractors Discussion Forum
Show Parts for Model:
Re: Looking for MM108 town country parts
JJ Moore
08-22-2013 07:04:21
The best way I can describe the part I'm looking for is as a transmission break. The piece mounts on the rod connected to the clutch pedal and stops the transaxle pulley when you depress the clutch. It is a little block with a hole bored through it with a set screw to hold it in place with a flat piece of steel welded to it with a small brake pad riveted on the end of it. The one I had wore down to the metal, I believe this was due to it being rewelded at some point causing it not to align properly, the pulley also chewed into the metal because of the alignment.
