Broke sparkplug in head
Dascher
New User
I broke off the sparkplug in the head of my G707 is there anyway to get it out without takeing off the head?
did it break off putting it in or removeing it? you can try an easy out, you'll need the size that'll be tight before it hits the electrode. if you broke it off by removing it i'd give it some heat first but you'll want to have a new plug ready to thread in once the broke is out so the hole don't warp
Just had this happen to me last night , take a small tip torch and heat the plug red nice and easy, use a high quality easyout and should walk right out , take your time as this will save you from pulling head .
The hole ain't gonna warp. He can heat the SNOT out of the remains of the plug 2 or 3 times, (allowing it to cool to ambient in between), and by then the remains will nearly screw out with a finger tip.
