driveway pto adjustment
G706
After getting the M670 PTO together and running for awhile with new plates the lever didn't snap in good so we had to do a quick adjustment so we could run the new baler (not the baler in the background). Quick means 2 hours.
Does yours happen to have the adjusting plug on the top plate to take out? Ive never had any luck with removing them to adjust anything. I have one on mine but not sure there is enough clearance to take it out. I know there isnt on my M5. If the plug would have been 1/4" farther ahead it might have worked. I had read in an I&T book that some of the later 670s had a plug on the right side (by the battery) to adjust the brake band but dont believe Ive ever seen one.
It has the plug, but as you know it don't work for adjusting. Early M670 has the plug on the side, but it's not easy to use either.
