AB FROM ILL
New User
BEEN PULLING A U FOR YEARS NOW, RECENTLY MADE SOME PIECES INSIDE TRACTOR AT A PULL. 8 YEARS AGO WHEN I BUILT TRACTOR FOR THE 2ND TIME REALLY HAD NO PROBLEM FINDING PARTS, BUT NOW IS A DIFFERENT STORY. WHY IS IT THERE ARE IH AND DEERE PARTS EVERYWHERE; EVEN PEOPLE THAT REMAKE THOSE PARTS AND BUILD THOSE TRACTORS? AND NOT MOLINES I HAVE LOOKED ALL OVER THE INTERNET AND CALLED ABOUT EVERY MOLINE SCRAP YARD FOR PARTS AND ADVISE. IM ABOUT TO SWITCH BRANDS SO I DON'T HAVE TO WAIT 6 MONTH FOR PARTS. SORRY ABOUT THE SOAPBOX BUT I ONLY MADE 2 HOOKS THIS YEAR. ANYBODY CAN HELP PLEASE RESPOND WITH SOME ADVISE.
403 CRANK,RODS,ALL FRONT GEARS PRETTY MUCH COMPLETE G MOTOR THEN I HAVE MACHINE WORK TO DO AND NEED TO KNOW WHAT SPECS TO TURN CRANK TO 6.5 STROKE DONT MIND SPENDING A SOME MONEY BUT ONLY WANT TO SPEND ONCE AND THEN PUT MOTOR TOGETHER LAST TIME I BOUGHT A KIT AND PUT IT TOGETHER CANT GET THAT LUCKY THIS TIME I GUESS
One of the reasons that MM parts are harder to find than IH, or JD, is they didn't build as many tractors and have been gone since the early 1970s.
Well, I have a gas G, U Special standard, 5 Star standard surplus to my needs. Might have something you need. Also local puller may have some parts I could give you his contact info. We also have several M5 and 602, G705,G1000 and others. My e-mail is open. Joe Central MN
all you need to do is call lawrence wilson in nc. he can get you what you need or can make it if you got the cash. he is the best moline builder in the south.
One: Ford built more 8n's than Moline built tractors!!!! 2. Not enough demand to mass produce parts!!!! I went through this with a rebuild this past winter (not a puller) took act of god to get simple parts (gaskets)
Searching through your rantings to figure out what you really need is a challenge, I have all the parts you mention or several complete 403 engines here in central NE. Freight trucks run everday. Give me a call 308-940-0255 Thanks Jeff
