Looking for MM108 town country parts
JJ Moore
New User
I had posted earlier that I was looking for someone or some advice as to where I could locate parts for a 108 town and country. I recieved some good leads and I appreciate all that took the time to get back to me. However I still haven't been able to find what I need. I have a call into the Stamm's in Kansas but haven't heard back from them yet and the other person I was told to track down I do not have a good number for. Does anyone have a good number for Ron Becker, I was told he may be able to help me. Currently I have a piece I manufactured doing the trick but I would prefer to get the correct part. I'm sure there are other things I would like to get for it if I had the contacts. If there is anyone out there that has a number for Ron please pass it on to me, or if there are other people you know of who sell parts for the town and country please send me their contact info. Thanks again for any and all help.
Try Clint and Kelly stamm. The have a website stammtractors I believe or just type in stamm Minneapolis moline you will find it.
I have several Jacobsen tractors for parts on the IL/WI 14 miles from Lake Michigan, if it's anything big, I don't like to ship. 847 three 0 nine seven 34 seven
The best way I can describe the part I'm looking for is as a transmission break. The piece mounts on the rod connected to the clutch pedal and stops the transaxle pulley when you depress the clutch. It is a little block with a hole bored through it with a set screw to hold it in place with a flat piece of steel welded to it with a small brake pad riveted on the end of it. The one I had wore down to the metal, I believe this was due to it being rewelded at some point causing it not to align properly, the pulley also chewed into the metal because of the alignment.
The piece I'm looking for is best described as a transmission break. It mounts on the rod connected to the clutch and stops the transaxle pulley from turning when you depress the clutch. The piece has a small brake pad revited on the end of it to conntacts the rear pulley when you clutch. Do you have this piece in decent condition? How much would it cost. I'm in Pennsylvania if that make a difference as far as shipping. Thanks.
