TractorLinks.com
Minneapolis Moline Tractors Discussion Forum
Show Parts for Model:
Re: Jet Star 3 super pto clutch repair
Alan K
08-18-2013 07:26:28
I had forgotten about the threads in the shaft. Been a while since I did mine. If I remember correctly I think my 950 was 9/16" fine thread. I had forgotten about it but now I remember that I had a hard time finding a correct bolt to use. Does yours have the snap ring holding the bearing in the rear housing as well?
brian(MN)
08-18-2013 09:29:35
 Re: Jet Star 3 super pto clutch repair in reply to Alan K, 08-18-2013 07:26:28
My shaft has 5/16 threads, so I am not getting much help with pulling from that, don't care to drill out a broken bolt just yet. I tried the pipe wrench idea, it does work, but no luck yet, that shaft is very solid. I will look into it more when I get time.
9/16 is rare, I needed a 9/16 bolt for something last winter, can't remember what for sure, maybe to line up a wheel to a hub?
Brian
Alan K
08-18-2013 10:18:33
 Re: Jet Star 3 super pto clutch repair in reply to brian(MN), 08-18-2013 09:29:35
I agree, 5/16 isnt much to pull from. Maybe using a puller and tapping shaft back at the same time will get it out. I would be leary too with that small of a bolt. If the tractor has been sitting a while there might be a small amount of rust build up on the splines by the clutch as well. I think I might have moved mine back and forth untill it came loose. You could make a collar to bolt onto the shaft in an open spot so you have more to tap against as well. It is fun working on older machinery until something gets stuck...lol
