Yesterday's Tractor Co.
Shop Now View Cart
Minneapolis Moline Tractors Discussion Forum
Show Parts for Model:
Re: Jet Star 3 super pto clutch repair
08-17-2013 22:19:36
Here's a picture of a puller I made from a piece of 3/8 all thread rod and a steel plate ( I think that part of the sickle drive off an Owatonna swather). Thread the rod as far into the end of the shaft as you can. This is on a M670 Super, I don't know if a Jet Star has the threads in the end of the pto shaft. As mentioned before take the key and the set screw out before using the puller. The rear bearings come out with the shaft.
08-19-2013 13:29:12
 Re: Jet Star 3 super pto clutch repair in reply to G706, 08-17-2013 22:19:36
g706 would you have anymore pictures of the inside of the m670 super pto i am redoing mine and need some pictures
08-19-2013 22:34:49
 Re: Jet Star 3 super pto clutch repair in reply to manitobafarmer12, 08-19-2013 13:29:12
Here are some more pictures. I thought I took more but I had it apart about 3 times and the camera got put aside. I had a lot of trouble getting the bearings seated all the way. I finally installed the shaft and then the bearings. Made a tool out of a pipe to drive the races in. Had the shaft in the first time and then found the threads on the shaft were messed up. Then I had made a new key, but it was a bit too long, but I finally got it.
Alan K
08-18-2013 07:26:28
I had forgotten about the threads in the shaft. Been a while since I did mine. If I remember correctly I think my 950 was 9/16" fine thread. I had forgotten about it but now I remember that I had a hard time finding a correct bolt to use. Does yours have the snap ring holding the bearing in the rear housing as well?
08-18-2013 09:29:35
 Re: Jet Star 3 super pto clutch repair in reply to Alan K, 08-18-2013 07:26:28
My shaft has 5/16 threads, so I am not getting much help with pulling from that, don't care to drill out a broken bolt just yet. I tried the pipe wrench idea, it does work, but no luck yet, that shaft is very solid. I will look into it more when I get time.
9/16 is rare, I needed a 9/16 bolt for something last winter, can't remember what for sure, maybe to line up a wheel to a hub?
Alan K
08-18-2013 10:18:33
 Re: Jet Star 3 super pto clutch repair in reply to brian(MN), 08-18-2013 09:29:35
I agree, 5/16 isnt much to pull from. Maybe using a puller and tapping shaft back at the same time will get it out. I would be leary too with that small of a bolt. If the tractor has been sitting a while there might be a small amount of rust build up on the splines by the clutch as well. I think I might have moved mine back and forth untill it came loose. You could make a collar to bolt onto the shaft in an open spot so you have more to tap against as well. It is fun working on older machinery until something gets
