ZAU Serial number
R B
New User
Checking a couple different sources, it looks like the last zau was serial #00614658. The serial tag on my zau is several numbers after that. Any ideas? Thanks.
Serial numbers probably not totally accurate in books. I know the serial numbers for UTSD-M have similar issues.
If I remember correctly my ZAU is number 00614637. Not sure about other numbers, thats puzzling... Do you have any pictures of the tractor you can post?
Here is a picture of it. Someone painted the sheet metal a different color but the tractor is in good condition. I have the correct headlights for it.
I traded an old pickup for a ZAU about 20 years ago and the tractor serial no. was 00605261. Nobody could tell me anything about the year of manufacture. Some thought it may have been a military unit. It still had the factory prairie gold paint. No sign of any other color.
Anyhow, I sold it at the farm auction 13 years ago.
You have a nice looking clean tractor. Some of the changes on the later ZAs from the previous models were: pressurized radiator, flote-ride seat, smaller reflector headlights with combination light for the rear, taller brake pedals, and the throttle rod was on the outside of the steering support rather than the inside. I believe most of the changes were in mid 1950 to 1951 models.
I have checked it several times and also had someone else read it and it is stamped 00614668.
