U puller issue
Anonymous-0
Hi, I'm in the process of putting a 403 in a UTU, and I'm at the point of putting it back together. I put the instrument panel on and then the gas tank, and the gas tank wouldn't go right into place because the heads are taller up. Should I grind the lip that comes out around the tank? Any suggestions? Thanks
Did you replace the rubber cushion that goes between the bracket and the gas tank at the front. Mine is about 3/16" thick and worked perfect. No interference.
