Here ya go Alan K
560farm
Location
NEIL
A few of the MM we have. The 955 is original except the fenders, I removed the cab. The Vista was painted some time before we got and didn't look at good before. I spent time and a lot of elbow grease to bring the paint out. I need to do the same to the 955 now.
Those are some nice looking workhorses. How did you know I like the Comfort King Cases. Interesting seat on the G955. That is one tractor a person just doesnt see much of. Even if it is half Oliver I always thought they looked ok. So what kind of work do you do with them? Taint no fun if ya cant get them dirty is it?...lol
I'll add one here that I saved from the scraper a few years back. My blood runs red but I just couldn't let this one go...
Casey in SD
Glad you saved it. Im sure I might have asked you before but where in SD are you at? Ive been looking for what they call the trunnion to put on my G950. It is the rear part of the front axle that mounts to the side rails so it isnt bolted to the oil pan. I do have a service bulletin somewhere on them. There were field installation kits for them. I have one here but want to make sure it is the right dimentions before I start drilling. I measured it against my side rails and thought it might be a little short but maybe I measured it wrong. What does yours measure from left to right, center to center hole?
That is a nice chunk of iron as well. It must have been 1974 when they removed the white paint from the sides of the hoods and went to all yellow?
I'm located by Toronto, SD. Extreme east-central SD, almost north-east. The tractor came from south-central WI. A family member alerted me to it.
If your talking side rail to side rail it measures 17.5 inches on center for the bolt holes. Mine is also bolted to the oil pan, looks to be from inside the oil pan.
Casey in SD
That is a comfortable aftermarket seat that previous owner had installed when the cab was on it. They get used for plow days, tractor rides and maybe pulling 500 bushels wagons in from the field periodically. They don't have enough HP to pull any of our tillage machinery. We have several CK Cases, always had Case and Farmall tractors.
I'll have to re-measure mine. Can you send me a couple of pictures of how it is mounted? Just want to make sure I have enough room before I mount it.
Glad to hear you came out. Hope you had a good time. It would have been nice if I could have found some traction. Should have taken the south side of the track.
Casey in SD
