TractorLinks.com
Minneapolis Moline Tractors Discussion Forum
Show Parts for Model:
Re: 705 head gasket failure/water manifolt leak
Captainhookerus
08-07-2013 15:57:36
Before you tighten head bolts you should bolt on intake and exhaust manifold to get heads aligned so manifold gaskets won"t leak. You really need a offset wrench as you have already wasted the price of one by not getting bolts torqued to 175 lbs correctly.
R Wyler
08-07-2013 19:21:21
 Re: 705 head gasket failure/water manifolt leak in reply to Captainhookerus, 08-07-2013 15:57:36
Yes I put the intake and exaust manifolds on befor tightening the heads. I will get one as soon as I can I learned the hard way again. Can I use the JDE 141 for that 175 pounds? I will try to get one as soon as possible.
This post was edited by R Wyler at 19:27:31 08/07/13.
Captainhookerus
08-07-2013 19:59:08
 Re: 705 head gasket failure/water manifolt leak in reply to R Wyler, 08-07-2013 19:21:21
You bet it is the same thing MM had.
R Wyler
08-07-2013 20:06:24
 Re: 705 head gasket failure/water manifolt leak in reply to Captainhookerus, 08-07-2013 19:59:08
Thanks for the info I will have to get one as soon as possible.
