Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Minneapolis Moline Tractors Discussion Forum
Show Parts for Model:
Re: M670
MMDEL
08-06-2013 08:20:40
All you need to do is get a two valve assy for a loader. Then you will have a float position for the loader. Run the main pressure line directly out of the pump to the loader valve and then from the loader valve to the line you disconnected from the pump. The three point and romotes will operate as normal and you will have a satisfactoy loader operation. The reason your 302 was slow, was you was using the tractor valves for the loader, and running the fluid through the tel-o-flo slows everything down. Also the 670 has a larger pump than a 302
MMDEL
Klw445
08-06-2013 19:23:34
 Re: M670 in reply to MMDEL, 08-06-2013 08:20:40
Thanks for the help. I may have to ask how to do it again when I finally get to that point.
