TractorLinks.com
Minneapolis Moline Tractors Discussion Forum
Show Parts for Model:
Re: M-5 powersteering leak
Alan K
08-04-2013 22:25:28
Which weep hole are you referring to? Most of the seals are O rings. There is a minor difference, O ring placement, in the older valve and the newer valve if I remember right. Ill have to look it up again to make sure.
Majorlucasyahoo.com
08-05-2013 16:17:12
 Re: M-5 powersteering leak in reply to Alan K, 08-04-2013 22:25:28
There is a cap on the rear of the powersteering control. It is held on with two bolts.
Do i remove the entire valve or can i ring it in place?
Thanks
Alan K
08-05-2013 20:20:02
 Re: M-5 powersteering leak in reply to Majorlucasyahoo.com, 08-05-2013 16:17:12
What is the serial number of your tractor? There were two different valves used on them, basically just "O" ring placement is the main difference....one has an O ring on the actuating lever and one in the end cap you are talking about. I THINK you can remove the cap safely and check the O rings. There are two small ones on the two bolts that hold it on. Here is a parts break-down of the valves.
Majorlucasyahoo.com
08-06-2013 06:51:30
 Re: M-5 powersteering leak in reply to Alan K, 08-05-2013 20:20:02
Thank you!
