Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Minneapolis Moline Tractors Discussion Forum
Show Parts for Model:
585 diesel
jeric
07-22-2013 11:06:11
Have a 1350 diesel with the tach not working. Anybody know how to hook one up if it has the external oil pump with no cable for the tach?? Seems to be electronic.
Captainhookerus
07-22-2013 17:47:48
 Re: 585 diesel in reply to jeric, 07-22-2013 11:06:11
This is a lot of work BUT. If you remove the blocking plug that is in place of old cam driven oil pump and drill a hole in it the same size as the old oil pump shaft about 1 1/2 inches deep. Put a ball the same size as hole in the hole then use a 585 oil pump gear and saw off shaft so you have about .010 to .020 clearance between gear and top of plug. The short shaft will ride on top of ball and you will have your cable drive tach drive back as it was before the external pump was installed.
Dieselbear
07-22-2013 11:57:54
On my 1355/585 diesel it runs of the alternator. Single post on the back of it
