TractorLinks.com
Minneapolis Moline Tractors Discussion Forum
Show Parts for Model:
Re: Plow Manual
kevin moschenrose
06-24-2013 22:20:38
Floyd county museum has re prints of them St. Charles Iowa. Just need to know your model of tumble bug. If is a TK or TW the TK has steel wheels and round tube type axle housings where the TW is rubber tired and uses square tubing. Also the is a little difference in the tongue as well.
kermkep
06-25-2013 19:20:21
 Re: Plow Manual in reply to kevin moschenrose, 06-24-2013 22:20:38
I also have a 2-16 tumblebug plow I'm trying to identify. Mine has 6 hole 15" implement type rims. Do you have an idea what it might be? I'd like to find a manuel for it also.
kevin moschenrose
06-25-2013 22:13:02
 Re: Plow Manual in reply to kermkep, 06-25-2013 19:20:21
On the Tumble bug with the 15" wheels and and implement type rims that is the later model one and and is a TW tumble bug plow it also has a different style tongue then the one in the picture and square tubing on the axle shafts where it says Moline at.
kevin moschenrose
06-25-2013 22:10:04
Hello, Yes i was a little vague on the wheel I.D. as a give away. The TK pictured is yes on rubber as you can see and did come out that way but a little hard to date them as rubber was hard to get during WW2 This one could be a post or pre war plow TK model. Mine is on steel and has a tongue and axle housing tubes "round just like this one as well.
Pardon the pun but they are a trip at plowing shows and fun I got a story on one show.LOL
ILL John
06-28-2013 11:19:23
 Re: Plow Manual in reply to kevin moschenrose, 06-25-2013 22:10:04
Kevin, Mine is a TK, it came on steel but I switched it to rubber like the one pictured, Charlie Doty had one on rubber to send to England, "I think", and he needed steel so we switched wheels.
kevin moschenrose
06-29-2013 09:42:27
 Re: Plow Manual in reply to ILL John, 06-28-2013 11:19:23
Yeah I wasn't too clear on that post and hit send before I really read it. One thing about steel the tire won't go flat on less you drag it.
RS Farms
06-25-2013 09:59:15
Kevin sent you a couple of pictures for you to look at. Thank you for the information.
MJ in the UK
06-25-2013 04:25:11
Hi Kevin, nice to see sombody who knows a bit about MM tumblebug ploughs. Over here in the county of Nottinghamshire I run a tractor club and we have a workig weekend every year. 3 years ago we featured tumblebug ploughs. One MM pulled by a ZTU, one MM pulled by a UK built UDS one MM pulled by a UK built Turner tractor, one IH tumblebug pulled by a Fordson E27N tractor on Roadless halftracks and finally a Case tumblebug pulled by a Case LA tractor. All 5 tumblebug ploughs had been imported into the UK in the last few years as none were brought here when they were new. MJ
kevin moschenrose
06-25-2013 22:14:39
 Re: Plow Manual in reply to MJ in the UK, 06-25-2013 04:25:11
Good glad you enjoyed them I know for a fact they sure are a crowd pleaser to see in operation.
