Light switch wiring on GTB gas
Anonymous-0
Does any one have a wiring diagram for the light switch on a GTB. I was rewiring mine but most of the connectors were off it before i started. I think ive got it wrong because the voltage to the ignition coil changes depending which position the light switch is in.
Is this the switch you have? This is original type switch used with generator and voltage regulator.
BAT is input, comes from either the L terminal on generator voltage regulator, or generator side of the ammeter.
IGN ACCESS goes to coil
LTS is lights
Ignore Mag and Gnd with distributor
Ya this is exactly the switch i've got. This makes it really clear. I forgot about the mag connections, that is why those aren't used. Thanks a bunch, Albert.
