90 degree tack drive
I would have the style that drives of the end of the distributor mount or the style that comes off the lower accessory drive under the distributor. Both of those are straight and I am not familiar with the 90 degree you are referring to. Jeff 308-940-0255
I sent one to Alan K or Jeff Laleman a while back. Dont know if worked for them or not. All models of 5 Star and early M 5s used them.
It must have been Jeff. I had gotten some other M5 parts from you a while back, front grille I know, parts worked well. Is this the part you are referring to Brian? This is from an M5 parts book, part number 10A12171 tachometer drive diesel. As Shaun said they were used on the 5 Stars as well (same number in parts book). I think they must have used these on the gas 5 Stars as well as I have one on mine.
All tach drive ratios are matched to tach itself. M5 diesel should be replaced with M5 diesel,M602 and M670. Basically any model with 336 diesel motor. 5 Star has different tach but book shows same part number.
