fredmich
I mow with a 184 Cub Lowboy that has a IH 60" mower deck on it. I would like to know if anyone has had to replace the thin metal strip under the deck that surronds the outline of the blades. It helps direct the cut grass out of the right hand side of the deck. Mine is missing some of it and some of it has come loose and it leaves the grass clippings in a streak on the l.h. side. Is it still available or does one have to be fabricated? Thanks...Fred
