UB battery tray
My brother made some battery trays that would fit on the newer MM's but I am sure they will work on the UB. I could check with him and see if they would fit.
I believe the mounting holes for the ZB and UB are different as they are offset compared to the later MMs. If he had a pattern for the holes maybe he could make some up. Do you have a picture of the ones he makes? What does he get for them?
Ken Hicks used to. I don"t have his contact info. You need to know if its lp or gas. They are different.
As Alan said, UB and ZB have different bolt patterns. UB gas and LP are the same. UB Diesel uses the same inner box as gas and LP, but has an outer box that is completly different. I believe Welters has them for UB and the newer style for M5-G1000. I have one UBD outer left I believe.
