TractorLinks.com
Minneapolis Moline Tractors Discussion Forum
Show Parts for Model:
Re: Gvi motor
toolz
05-30-2013 08:35:48
A 425 with a 605 crank will get you about 510". You will need custom pistons for the longer stroke. If all you want is about 510", it"s a lot easier to use 504 jugs and pistons on your stock bottom end to make it a 504. The easiest way to make a 605 is to use 605/403 jugs, pistons, and pushrods with the 605 crank, or just bolt in a 605.
*richy*
05-30-2013 08:53:27
 Re: Gvi motor in reply to toolz, 05-30-2013 08:35:48
I have 504 jugs,
toolz
05-30-2013 09:41:43
 Re: Gvi motor in reply to *richy*, 05-30-2013 08:53:27
504 jugs are the same bore as a 605, but are about 2" shorter. Using 504 jugs with the 605 crank will get you a 605, but you will still need custom pistons for the shorter 504 jugs.
*richy*
05-30-2013 09:49:31
 Re: Gvi motor in reply to toolz, 05-30-2013 09:41:43
Could i use 605 jugs, 605 crank and use my current pistons
toolz
05-30-2013 15:58:44
 Re: Gvi motor in reply to *richy*, 05-30-2013 09:49:31
425 pistons are a smaller bore. 504 pistons have the wrong compression height. If you use a 605 crank, you will need 605(403) jugs and 605(403) piston, unless you get custom pistons.
MM diesel
05-31-2013 08:27:42
 Re: Gvi motor in reply to toolz, 05-30-2013 15:58:44
I always knew that "G" pistons had the same bore as a 336/504 piston, but I never thought about the compression height being different. I learned something today, but I will still stick my diesel MM toys.
jd plowboy
05-30-2013 14:29:10
get you three 403 jugs, 6 403 pistons, and 12 403 push rods. if you find a 605 power unit it will be the same parts.
