M602 Engine trouble
cleddy
I have been using my M602 to travel about 10 miles to my parent's farm to clean it up and made the trip several times but the last time it developed a engine noise like knocking or clicking about mid engine. I had to limp along about 4 more miles and load a trailer load of scrap metal and pull it out of the mud up to high ground. Oil level was good and oil pressure is 30-40 lbs and it was still operational when I parked it. We have had some problems with antifreeze in the oil(stopleak solution) so maybe it been running on antifreeze but the oil on the dipstick looks okay.
Does this sound like I lost a Rod bearing or something. How long can I expect it to run yet before it self destructs. I hope to get it on a trailer before it blows up for good since driving 10 miles back probably isn't going to be an option and towing with out steering is difficult.
Can anyone venture a guess what is wrong without seeing or hearing the problem??Cleddy
Does it only do it at mid throttle, does it go away or get worse when its cold or warm? Or is it always the same
It is not to bad at mid throttle and kind of goes away when I rev it up and then starts again. I am afraid to run it to much wide open but was able to rev the engine up enough to drive it on and off a trairer and get it where it needs to be and drive it to park it. It almost sounds like a fan blade hitting something but that doesn't seem to be the case. Thank goodness them engines run slow and are a little forgiving of abuse or it would be all over by now. I may need a different engine yet if I can't figure it out.
cleddy
So the noise is coming from the block, or somewhere by it? If it is from motor, it could be a rod bearing, hard to tell when you can't hear it run.
Sometimes a worn rod bearing will give a double knock from slack and will run for a long time but better look into it. I had a 79 IH truck ran for years with a slight rod knock. Hope it all works out.
Thanks for the input. I will take it apart when time permits. The book says a M-5/M602 is 6400#dry weight. I would sure like to know what wet weight is with fluid in main tires,duels,oil,water,a heavy home made cab plus a wl-30 Westendorf loader w/7' bucket.
I drove it up on a 10,000# trailer to move it and the tires all looked almost flat and the fenders were about touching the tires. I made the small trip but maybe put that on the list of things "never" to do again.
cleddy
