TractorLinks.com
Minneapolis Moline Tractors Discussion Forum
Show Parts for Model:
Re: M602 Engine trouble
G1355
05-06-2013 13:50:33
Does it only do it at mid throttle, does it go away or get worse when its cold or warm? Or is it always the same
cleddy
05-06-2013 20:13:34
 Re: M602 Engine trouble in reply to G1355, 05-06-2013 13:50:33
It is not to bad at mid throttle and kind of goes away when I rev it up and then starts again. I am afraid to run it to much wide open but was able to rev the engine up enough to drive it on and off a trairer and get it where it needs to be and drive it to park it. It almost sounds like a fan blade hitting something but that doesn't seem to be the case. Thank goodness them engines run slow and are a little forgiving of abuse or it would be all over by now. I may need a different engine yet if I can't figure it out.
cleddy
G1355
05-06-2013 20:15:30
 Re: M602 Engine trouble in reply to cleddy, 05-06-2013 20:13:34
So the noise is coming from the block, or somewhere by it? If it is from motor, it could be a rod bearing, hard to tell when you can't hear it run.
