water jacket leaks on za cylinders
Anonymous-0
Got my za motor running today after having the valves ground. Got it running and went to put coolant in it and found out it has a pretty bad water jacket leak into the exhaust port. Is there anything that can be done to fix this or is the cylinder junk? My machinist magnafluxed them and told me they were good.
I had two last year on rebuilds. Redo blocks and appear good until coolant added. They crack above valves. Very hard to see. Blocks end up scrap.
