Yesterday's Tractor Co.
Shop Now View Cart
Minneapolis Moline Tractors Discussion Forum
Show Parts for Model:
Re: MM 1355 diesel injector timing
05-01-2013 04:58:04
I am still missing something. I looked at the tractor today and do not see a bell housing or a window to the fly wheel. On the H balancer/pulley, I see a mark but nothing to reference it to, ie an index plate. The mark may be a ding from a wrench or rock.
Unless I am missing something, I can't use the injector pump to time it because the pump has been off and rebuilt and the tractor has been turned over while the pump was off. The injector pump drive gear is not aligned to the fly wheel-cam shaft and the #1 compression stroke.
Looking at the service manual, If I disassemble the front of the tractor and expose the flywheel, there should be an index mark on the flywheel and the cam gear that will time the crank to the cam. If I turn the engine over until I am on the compression stroke in #1 with both valves closed, then how do I determine 4' ATDC? There does not appear to be a scale on the crank-cam alignment (although I am just looking at a picture in the book).
If I could figure that, I could install the injector pump and follow the manual to static time it.
I have not disassembled the crank-cam gears so it is on the same setting it has been on since 1972.
What am I not seeing here.
05-01-2013 16:33:30
 Re: MM 1355 diesel injector timing in reply to Onewaydave, 05-01-2013 04:58:04
OK. I've got it. Thanks to mm fan and smoking minnie and everyone who responded. You were right, I just couldn't see the forest for the trees.
Yeah, static timing will be easy now that I know where to look. No need to pull the front end stuff off.
Picked up the rebuilt injector pump today. Pricey little things, but that's why they last 41 years and make our lives so much fun I guess.
Later guys.
Dave, thanks again.
smoking Minnie
05-01-2013 06:15:23
Look through the big round hole left frame rail at back Flat piece of metal in the middle of it with one or two screws holding it on Remove screws pull little plate It is about the size of a silver dollar That is your timing Window has a pointer in the center that lines up with numbers on fly wheel
