Middle hydraulic lever on a 602 flops around, what happened
KCTractors
Location
Central Wi
The middle hydraulic lever was in neutral position or in line with the other two and then it felt like something let go and now it falls back further than the other two levers, when I use the 3 pt lever it moves the center lever too, if I don't hold the middle lever, so what happened?
Im guessing the centering spring for the lever broke. That is the external spring that is held in place by the "peg" under the levers. I would check that first. There are a couple places that sell the external bolt on spring assemblies, otherwise I guess you have to disassemble the hydraulic lever assembly to install them.
