TractorLinks.com
Minneapolis Moline Tractors Discussion Forum
Show Parts for Model:
Re: MM 1355 diesel injector timing
Cliff Nelson
04-30-2013 05:19:35
The flywheel is marked but you need to know when #1 is on compression stroke. or you can have the pump 180 degrees off. If you have the injectors out you can cover the #1 injector hole as you turn the engine over. when you feel pressure it is on compression stroke and you can line up the mark on the flywheel. If the injectors are still in you can remove the front valve cover and watch the rocker arms as you turn it over.When #1 intake valve closes it will be starting the compression stroke.
