TractorLinks.com
Minneapolis Moline Tractors Discussion Forum
Show Parts for Model:
Re: L.P. tank
jnf
04-23-2013 04:58:13
LP is heavier than air, so if you can bleed a little vapor from top of tank, that takes care of any air quite readily. The tank fittings, if original, should have "excess flow valve" that will close in case of a ruptured line. Possibly this valve is stuck closed. Remove line from tank valve and open the valve to check for what should obviously look like a good flow. Tractor should run quite well on any amount of fuel.
toolz
04-23-2013 06:26:01
 Re: L.P. tank in reply to jnf, 04-23-2013 04:58:13
Thanks- should have known that. I"ll shove some more LP in it tonight, and bleed it some.
