Hello,
my nephew was grading the driveway a couple weeks ago, and tractor stopped moving, no forward in any gears or reverse, sounds like something spinning in the diffential, but cannot be sure, ampli-torq in hi or low, still no movement, when the tractor is running and the clutch is out, I can slip it into first gear, tractor does not move, it will not go into the other gears, they grind like the should without depressing the clutch, I have top cover off of trans, I see the shifter forks and the gears, what should I be looking for that may be out of place? or is it something in the differential.??
help!!
help!!
