G704 on the dyno
Well since its too wet to do anything else, We finally got the 704 on the dyno today.. Just wanted to check everything out after having the injectors and pump rebilt. Definatley a good way to play till the feild work begins. Also I am curious has anyone else dynoed down their GVI or 704 and their hp numbers.
Our Gvi with advanced pump timing and pump work pulled 116 after overhaul , it has a 3 core radiator to keep cool.
Thanks for the replies and pics.. Real nice tractor and pics M5jack.. Sounds like she is real stout. I will just try to make up for it in traction. Thanks again, I enjoyed the pics..
The ground was wet plus Illinois muck. Plow was a 4/16 4440 oliver that somehow wound up mm brown with praire gold wheels and coulters. She was in third gear around 6.5 mph since 2nd gear needed replaced. The hidden tractor was a 720 JD with pump turned way up.
